Ignoring Lambda warning when limiters are active?
WinOLS Mastery: Map Identification & Editing
Discussion and questions related to the course WinOLS Mastery: Map Identification & Editing
Is there anyways for me to setup the the lambda warning to be ignored if I’m on a limiter? When the traction control is active my lambda warning activates from the ignition cut driving the lambda lean.
Bob W
That is interesting. In the help for Exhaust Lambda Warning, it states that the Warning will not be active when Fuel or Ignition Cut is active. Perhaps you need to tune some of the time values found within "Exhaust Lambda Warning Delay". Specifically the Enable Delay would add time after the Fuel/Ignition Cut before the warning would be enabled. Or the Activate Delay could be used to filter out spikes, or temporary conditions that correct themselves.
