DBW set up
Boost Control
I have a 90mm throttle body it is cable and through out the concentric twisting wiring harness they said that they will be using DBW throttle body in the future, my question is what it where can I find a complete set up that is 90mm, or can I just use a a GM DBW throttle and the pedal or what else do I need, I'm using ECU MASTERS Black edition ECU
You're able to use any DBW throttle body and pedal you have access to. In the larger throttle sizes GM are usually a good option so that's what I'd be looking for.
Anyone has a write up how to wire DBW throttle and pedal to ECU master black edition
