Epoxy Potting Compound
Boost Control
just seeing what Epoxy people are using I am in Australia so I might not be able to get what you can
thanks
Standard household epoxy resin...just check if temperature is an issue
I did find this MG Chemicals Black Epoxy Potting and Encapsulating Compound, &
Loctite EA E60NC - Epoxy Potting Compound - Non-Corrosive
The epoxy I'm using for potting is Raychem S1125. No idea if it's available in Australia though!
thanks, Frank I will check
