Link plug-in Honda S2000 fuel pump don't start
Boost Control
Hello friends,
I'v just fitted a LInk plug-in ECU in an S2000, ready to start, but don't. I have discovered the fuel pump don't longer receive power to turn on. Actually, I don't find where I can manage this in the software. ANy ideas?
Thank you veru much for helping!
David
David,
The manual for that unit explains there's a jumper that needs to be set depending on the market of the vehicle, for the fuel pump output to work. See page 7.
https://linkecu.com/documentation/S2000X.pdf
If you aren't sure which of the two options suits your vehicle, in this case the other ECU pin is unused, so you can test the other jumper position without causing harm.
o nice thank you very much, it works! :)
Awesome! You're welcome.
