Bosch M5 ABS + Prop Valve
Brake System Design and Optimization
Hi All,
Are prop valves still used with aftermarket abs units? Especially in the case where the unit is unpowered?
I don't think so. I'm 99% sure (will double check) we don't run the proportioning valve in the SR86 with the Bosch ABS.
Checking page 4 of this: https://www.bosch-motorsport.com/content/downloads/Raceparts/Resources/pdf/Operation%20Manual_70618763_ABS_M5_Kit.pdf
There's no prop valve shown, and I don't think it would be necessary.
