WOT log file
Brake System Design and Optimization
When doing a log at WOT with HP tuners on an LS1 do you require the pro version with wide band to do this to copy and paste the errors. I have a wideband on my dyno but I have only the standard HPtuners dongle. I've been tuning the VE table based on the load sites in the log vs my wide band on the dyno. I think I'm doing it the hard way but am only self taught with the efi stuff. I'm a carb guy.
The Pro version of the MPVI interface has the provision for analogue voltage inputs that can be used for a wideband. I actually input the Innovate LM2 into the scanner directly to my laptop via serial which I believe you can do with either dongle.
you can get the innovate Motorsports LC2 and run it through a usb port on laptop then select it in the serial section in the channel add box and you can log wideband data with HP Tuners standard and not have to buy the pro if your funds are limited at the moment.
