Hwo to setup normal throttle for cold start
Variable Cam Control Tuning
hello!
i have an m50 engine already did the base map and the car is starting smoothly, but the cold start rpm doesn’t function as per the table and stays on the normal idle.
starts 900 rpm even on cold, how i can tune the throttle to start 1300 rpm as it should?
Assuming you have already followed the instruction in the help file to tune the base position table, then I would suggest your next step would be to do a PC Log of the engine starting and warming up. Post that and a copy of your map here. We will then have some clues as to what is wrong.
Thank you!
