Idle speed valve control on starting
Variable Cam Control Tuning
How to control the automatic command that Link ECU gives to the idle valve while cranking to open at 80% as my engine isn't starting until I completely close the idle bypass and then open it after engine catch and RPM get above 400
If you go into the Idle speed control options there is one called 'Startup Step Table' This is the one that opens the idle control valve during cranking to increase airflow
Thanks for your reply
but it didn't work as I have checked it and adjust it but still having Link commending 80% when first cranking
Could you post a copy of your map and someone will be able to look at it?
