Aftermarket Ignition coils
CANBus Communications Decoded
What makes an aftermarket ignition coil better or worse than an OEM version? When is it necessary for you to upgrade your ignition coils to aftermarket.
Hi. I have tried a few different aftermarket options from middle to high price range and my experience tells me it's not worth it. But it depends on a particular car brend a lot. For instance, Mitsubishi stock ignition coils are very good up to 500+ hp. I guess then you go above 100+ hp per cylinder it would become better off to get stronger ignition spark ( that is privided by aftermarket coils). Having said that we need to remember that a good spark is always a benefit regardless of power level as it helps low RPM range torque and fuel economy...
Bottom line is a higher performance - voltage and/or current - coil won't add power if the OEM is already sufficient.
However, there are times when the OEM is barely capable of meeting the stock ignition requirements - early GM HEI for instance.
The main limitations of coils are RPM limitations due to required dwell to 'recharge'them, and the output voltage - increasing spark gap, cylinder pressures and/or difficult to ignite fuel mixtures can be a problem.
Not much direct help to you, especially as you don't mention the vehicle in mind - some OEM coils are actually regarded as high-performance replacement parts for other vehicles' coils.
You should be able to find the limits of your OEM coil(s) in discussion boards on your vehicle/engine, or in practice you may find you have a misfire on one or more cylinders, which 'may' be accompanied by a 'lean' condition because of unused oxygen in the exhaust - NOTE, this is not common as the other hot combustion gases will usually ignite it in the exhaust and it can be heard as a backfire. 'Lean' may also be a true lean condition, so treat any indications of that with caution - heck, sometimes a rich misfire can show as lean, if the fuel is too rich to ignite.
