Mil light on a non factory instrument cluster
CANBus Communications Decoded
Relevant Module: Worked Examples > Hondata KPro/S300 > Step 3: Configure Base Tune File
Hi. I am working on a project that is a locost (lotus 7 clone) using a K24 engine with 08-09 tsx ecu and hondata flashpro. I am not using the accord euro instrument cluster but want a visual indication of a MIL light on the dash. What is the easiest way to do this without using a factory instrument cluster ? There doesnt seem to be any direct connection to the ecu as an output for a Mil light. Does this need some form of converter to go from a OBD2 type connection to a physical light/led output on the dash?
Cheers
Simon (Brisbane Australia)
Have you asked Hondata the best way to do this. They may be able to program one an I/O either on the OEM board, or their add-in board to provide MIL functionality.
