Antilag help
Data Analysis Fundamentals
can someone assist me with my antilag im looking to do the off throttle bang bang thing ( antilag to hold the boost )
I have link ecu g4+ and kinda not that familiar with doing it yet I know that I need to open the throttle a little by adjusting the screw
can someone take a look at my setup
I have antilag off in the attached file
but you can do whatever you need :)
thanks in advance
by the way I know it is bad and ill have it on a switch but the car is a drift car so I need to keep the boost in
hello this map is set up for nonturbo use i will show you a e85 ignition map to suit what i use for drifting without using anti-lag
i will make it to 300 kpa or 30psi boost https://www.dropbox.com/s/smzoulsopyxd33b/Screenshot%202021-02-10%2020.37.20.png?dl=0
Regards Ross
