INNOVATE LM2 DUAL WIDE BAND ( HELP )
Data Analysis Fundamentals
hey guys , how are you all .
Does any one have any info , what is the Input value A :
Input value B :
Output value A :
Output value B :
for the innovate LM2 wide band dual sensor , i am using only one sensor
Inputs and outputs are for the expansion loom. Have you got these on your display?
hi Chris ,
i have connected the wide band to the plug and play ecu , ( one connection to the GRD and the other to the VOLT 8 ) and i have configured it , but it is giving an error - GRD error , i need the voltage specs , to configure , or it is the same configuration of the ( innovate -LC) which we already configured in the link .
Mosto,
LM2 Outputs are 0V = .500 Lambda 5V = 1.523
I always compare AFR readings in the ECU vs what the LM2 will be reading on the display.
Some adjustments may need to be made to getting it reading accurate
Also ensure your analog volt errors are set correctly for that particular channel
ok will do
