TB48 Base Map for Link or Vipec
Data Analysis Fundamentals
Would anyone have a base tune for a Nissan TB48 on a Vipec or Link Platform?
I'd like to have a look at the trigger and VCT Set-up and compare to the Haltech as the Haltech TB48 Trigger isn't an option with the Link ECU.
The trigger is similar to a RB26 or RB20.
The VCT for stock cams will work well if switched on at 1300 rpm and off at 4700 rpm and load of 50% throttle plus.
Thanks for the Info Bujasaim!
Do you also tune a 4D Fuel and Ignition Map for when the VCT is switched on like the Haltech Pro Plugin does?
I personally don't. I can get away with the main fuel table.
Thanks,
Do you just set-up the Aux Output much the same as an RB as in switched cam based on 3 parameters?
Looks like the RB's are the 360 Opto trigger.
Thanks for your help.
Setup a GP output for the VTC with the three conditions I mentioned earlier.
The trigger is a 360 optical same as the RB engine. But you have to do eccs test in the trigger setup. The trigger angle is around 80 if I recall well.
Hope this helps.
Sure does,
Thanks Again
