6.4 powerstroke tuning
Diesel Tuning Fundamentals
Truck is a 2008 f350. We purchased 100% over nozzles, a dual fueler kit with a cp3, and a s400 kit. We put an s480 on it with a .110 housing on it. Not surprised at all that it takes years to spool but what are some things we can do to help it spool alittle better and reduce smoke. I eliminated lambda limiting just so I could visually see what effects my changes were causing. What are some things I should be looking for right off the bat to dial the truck in closer to where we want it. Truck is strictly going to be racing and occasionally hooked to a sled.
I would re-introduce lambda control, even setting things on rich side will spool better than full-pedal fuel. Raise your shift points 15-20%, loosen the converter, and check for boost leaks (for the love of god). Most trucks at this level have several.
I really love the way those factory compounds run, you're in for a challenge getting anywhere close to reasonable spool-up.
Nick
I agree this turbo setup will never spool like the factory compounds, however I believe something reasonable can be had. Lol
With the vgt switch disabled does the truck still rely on ebp sensor for fueling? Or can I completely get rid of it.
I think you can probably kill it if your kit doesn't have mounting provisions.There is an EBP limiter in the later trucks, but it's set high enough that with a 480 I doubt you'll come near it. Still, it can be helpful to know EBP from a tuning angle.. just a thought.
Nick
Solid advice. Will likely weld a new bung in the uppipe to accommodate the factory sensor so it can be monitored.
Would you be willing to assist in this file? I’d really like to be able to spool this without nitrous if need be, and I just can not get it dialed in
