Asffect of AF
Diesel Tuning Fundamentals
Relevant Module: Diesel Fundamentals > Effect of AFR on Power and Torque
Why does a lower AF ratio result in higher power but not result in more boost pressure?
I used to run turbo engine without any boost control and bigger power always resulted in higher boost. Once you introduce any mean of boost control your boost level is limited as per settings...
