2jz swap in gt68
EFI Tuning Fundamentals
hey every one I'm going for swamping a 2jz vvti using link 4x fury but I'm very curies about using input and output from engine ecu,as its has gm external map sensor and e-throttle plus its will be street legal that means i have to make the ecu be comparable with Toyota can bus circuit
my issue is i need wiring sample so tat i can compare mine to make sure tat I'm using the right input and output
Unless you intend to reverse engineer CAN bus yourself, I'd get in touch with Link directly since that seems to be a key element of your project.
Their GR86 plug in unit documentation may have wiring info that's helpful to you as well.
