Starting issues with a 94 Supra 2jzgte non vvti with an EcuMaster Emu Black
EFI Wiring Fundamentals
Hi Community, have some trouble to start my engine after a lhd and single turbo conversion with a ecumaster emublack.
Have 2x 525lph Hellcat Walbro's, 1000cc Fmic Injectors, NGK U5002 Smart Coils (VAG Coils like the Audi R8, only a shorter version) Aeromotive Pressure Regulator, all ref and synch sensor are stock. All Output Tests are working flawless... no Trigger Errors, FuelPressure is around 3bar (tried also litte more and little less).
uploading my basemap, datalog for emu black and a short videos (last one with activated "batch all injectors on Engine start parametres", otherwise it doesnt come that close to the starting point).
Thanks for any help :)
Just checking since you said "(VAG Coils like the Audi R8, only a shorter version)", you know the short coils have a different pinout to the R8 coils right?
Short VAG:
R8:
Hi Adam, the wiring is correct like in your picture, i know that difference in wiring before :)
the car started, injection phase was off the ignition output settings and also changing the cranking fuel helped. now i have to set up correctly the afterstart and warmup settings :)
Im only curious, has anyone an idea why this setup with the ignition output /event and injector phase / ignition event works for me?
Has it anything to do with the "start on ignition event" option?
