Fuel Temp
Emissions Tuning Fundamentals
Discussion and questions related to the course Emissions Tuning Fundamentals
Hello all,
What fuel temp range would be considered normal for gasoline pump 99 Ron??? I've fitted a temp sensor but jo idea whend it's too cool or too hot? I have a return line 19row Mocal cooler also.
Are you having issues that you think are fuel temperature related? 99RON is a pretty stable fuel with a boiling point from 30 degrees C to 200 degrees C, it's flash point isn't until it reaches 280 degrees C.
What do you mean by too cold?
Hi it seems the sensor is working well having looked into it more... the fuel cooler seems to be doing its job very well indeed. I was wondering if my readings were spurious or calibration was accurate which it does seem to be.
Thanks.
