Discussion and questions related to the course Emissions Tuning Fundamentals
I have an 2007 Audi 2.0t fsi that I have upgraded. I have upgraded the intake, the turbo was changed from a k03 to a f23t frankenturbo. I have also installed a HPA intake manifold that has 40 % increase in volume and 24% increase in flow. My question is how should I adjust this into my tune. Should I increase alpha n table by 40 % or somewhere else? Also should i do the same with maf sensor?
What are you using to tune it with?
I am using Eurodyne maestro.
Can you post a link to a file with table descriptions?
I could post my base file but without maestro I don't think you can view it. Here are pics of the maps
Second pic
Third
That is only one portion of what is important. Do you have a PDF help file with descriptions of what maps are available?
Yes each map gives a small definition. Thank you so much,any help is appreciated
I guess what I am looking for is some guidance to which maps to adjust and maybe some how a starting point in how much to change.
You need to post a PDF or list of the table descriptions.
Here is a picture of the maps. If any needs a description let me know
n
