Solder Sleeves
Emissions Tuning Fundamentals
Relevant Module: Practical Wiring Harness Construction Skills > Splicing to Shielding Braid
Discussion and questions related to the course Emissions Tuning Fundamentals
Are solder sleeves preffered over crimps? or is this only used in case of grounding the shield?
It seems a lot quicker and easier. But i always thought it was more of an sloppy hobbyist application. And i heard you guys mention that crimps are preffered over soldering, how is this low temperature solder in a thin heat shrinking sleeve any good? isn't it better to just solder it with a soldering iron and cover it with thick decent heat shrink?
Solder sleeves are good for things that don't crimp well (like braided shielding), and it's a good solution for field splicing for those without good crimping tools.
