Economical suggestion for DXF drafting
Engine Building Fundamentals
Hi all,
Mechanical engineer here. Had extensive experience with solidworks early in my career but naturally can’t afford the seat for home use.
I have 4 parts I need drafted for send-cut-send that do not fall into their “templates.” I don’t have enough parts to justify a software purchase in the hundreds. Any suggestion on something economical I can use for a 2D DXF file?
Need to fabricate a spacer for the brake calipers, retaining ring for my McPherson tower mounts, and a bottom-mount cradle for the track seat.
-Aydin
You should be able to do this in the free version of Fusion, just create a 2D sketch then right-click the sketch in the browser and select export as DXF.
Alternatively try the free version of Onshape.
