Booting the AMP Superseal 1.0
EV Fundamentals
Discussion and questions related to the course EV Fundamentals
Are there any proper alternatives for booting and sealing the AMP Superseal 1.0 connectors? I've found some aluminium covers on eBay which Will give a neck to shrink a molded boot or SCL onto, but I'm wondering if anyone has experience doing this and what materials you've used.
I also found this 3D printable part, but does anyone know where to find something more durable?
Hey man, I ran into this same question and actually found an adequate solution for booting the AMP Superseal 1.0 Connectors using a backshell as you mentioned. Milspecwiring.com (aka MoTeC) sells the backshell on their website and even specifies the specific Raychem boots to use with each backshell depending on the connector size/density.
Here are the links: https://www.milspecwiring.com/RaceGrade-Backshell-Black-26P_p_1685.html
https://www.milspecwiring.com/RaceGrade-Backshell-Black-34P_p_947.html
Cheers mate
Brilliant! Thanks!
