SR20DET ECUMaster Black and Nissan Trigger Wheel query
General Car Setup Discussion
Hi all,
I have my car running on a ECUMaster Black (S14a) and the car struggles to rev past 5-6K RPM.
I noticed on my logs that the CAM Sync Trigger tooth value dips as the car is spluttering, see image attached. would this indicate an issue with the OEM Nissan trigger wheel? I do have an AEM trigger wheel I can put it on at the weekend but wondering if this is likely the culprit before I go digging into further diagnosis.
Thank you. I have attached an image and log file.
Gabriel.
Are you sure there isn't an overboost limit? It sure looks like it cuts when you get over .8bar of boost (1.8 bar MAP).
