Hi all
thought I’d say high, decided to sign up after the webinar last night. Neck deep in a unique old bmw engine build.
Building an high comp m30b35, trying to push the 12valve big 6 as far as I can.
Cheers
ant
Hi Ant,
Welcome to HPA. What ECU are you going to use to control it all?
I’ll be running an ecumaster, engine builder/tuner preferred choice & they work well on the old 12valve m20/30 bmw motors.
Lots of fab work & trial/error in setting up this build
