Awd 4g63 swap
So I am picking up a 92 eagle talon tsi and it has everything but the motor and harness and this is a donor car for a 2013 dodge dart. As I am sure you all are aware the fiat engine in the car just isn't enough for a 3600lb car. So a need for a more stable top end car is a must. The entire end game should land me about 600 hp. And if it makes just shy of that i will stop due to the reliability factor. If anyone has any suggestions or any incite on anything to make this a bit easier, I am all ears.
