ms3pro PNP miata not making power
Hello,
I have done a few ms3 installs with good results. I recently took in a NB miata racecar with a 1,8BP motor and stock ecu. We did a pre dyno with stock ecu and made 113whp. I installed the ms3 PNP unit, wired wideband, set base timing/fuel pressure, everything looks good. Moved over to dyno and got fueling and timing squared away. I am just not making the power it should be. My last dyno pull was only 97whp. This has been the first time I cant make more power than the stock ecu. I have attached my TS project and a log from the last dyno pull. Let me know if you guys see anything major. The power band also seems pretty dippy..
Edit: it wont allow me to upload the .msq file. so heres a link to download it.
https://file.io/wyvk1WQ270UT
and the datalog:
https://file.io/t9USRun83LxU
Thanks
