Traction control on fueltech ft450
Hi guys, i have an Opel corsa b swapped with a x20xev forged turbo engine. The turbo is an hybrid Holset hx40/35. The car has power but no traction at all. What do i need to be able to use the simplest traction control method?
I was thinking about adapting an abs sensor on one rear wheel and use the original speed sensor in the front. Is this possible? Apart of that i am not sure how to configure it.
