3sgte Boost Control Issues
Hey everyone, I am having some issues with hitting boost cut. I will admit I am still learning how to properly tune and the adjustments I make do not seem to be making any difference. I'm trying to keep the boost down to the low 30s. The original tune that came with the car was hitting a little over 40psi and I definitely don't trust whoever tuned the car before. I'll attach a log of driving it and the current tune I have on the car. I left the WGDC chart unchanged and it's obvious that isn't correct. I have tried smoothing the curve out gradually and lowering the duty cycle to 20% in the higher RPMs, but didn't seem to make a difference with hitting the boost cut. It's a fully built 3sgte with 2150cc injectors and a precision 6466, GSC 272 Cams. This forum has been a ton of help in getting this car going and I really appreciate all the knowledge people have to share! Thanks
https://drive.google.com/drive/folders/1XtYC-29QyOnGQcq_E84sd8MBQIfL4-LA?usp=sharing
