7AGE EMU Master Classic Problems
Hi Guys, ive recently finished a 7AGE MRP long rod build using a single FBW throttle 70mm and plenum, i have an EMU Master Classic and have got to the stage of a first start, my primary trigger and home trigger from the 24 and 1 tooth distributor are being picked up well and im getting a sync signal once im cranking, i get it to fire on cylinder 1 only, if i crank with the plugs out i only get cylinder 1 and 3 to fire but using the test option i can fire all with no problems, i even thought i'll change coil outputs 2 & 4 in the software and the output plugs but same deal 2 & 4 wont fire, what am i missing...
any help would be appreciated
