bmw e36
hi i want to make reflash to bmw e36 what di i need tools for reflashing like cables and software, and can i read the file from obd or i need bench way the ecu is ms41.0
Afaik...you need to do it on the bench,.. for ms42 onwards, there is a lot of info here...
https://www.ms4x.net/index.php?search=ms41&title=Special%3ASearch&go=Odeslat
Probably Ktag, Kess flasher should work for this old ones too.
Just came across basic info video for these older BMW Ecus… might be helpful…:
[url=https://youtu.be/yDXPBlh53Fs?si=ksbDjlB1yOwDPitA]https://youtu.be/yDXPBlh53Fs?si=ksbDjlB1yOwDPitA
thanks man that's very helpful
