Crank Sensor Blip
[img="blob:https://www.hpacademy.com/91af099a-874e-4c5d-9a4b-6cd92fb60fa9" alt="" alt="" ]Hoping to get some help on this, running custom built bmw f800 r engine on E85, using syvecs S7. Engine runs and idles fine, but at higher rpm getting some noise on the crank sensor input, where it drops to 0 then reading returns (blue trace is rpm). This is then messing with engine sync, brielfy sending it into stopped, then 360 then back to 720. What could be causing this?
