Hi I just want to say thank you so much for this course
but my question is you found those map depends on screenshoots, for my case for example I want to find maps for my suzuki gsxr1000 how I can find this screen shot and factor number to define my maps to start tune it not just my bike any ecu file how ?
thanks .
I'm following.
I think it depends on your control unit what the maps look like (Bosch, Conti, Delphi, ....).
I've was able to get around this using defined files from similar ecu software in winols, you can also line the hex data up, connect both windows, then transfer the map structure.
I've discovered doing this, regardless from what's said in the video, the axis data isn't always in front of the map data, in my case it wasn't even close, had to locate some axis purely by looking at the text data.
Either way it doesn't get around needing an original base to start from, basically someone else finding the pattern for you, be it a picture of the maps, or an already defined ols file.
I do feel winols mastery is a bit of a gloryfied title, even though there's incredibly valuable information in this course, it could delve alot deeper, winols is incredibly powerful, once you start to grasp it.
