Detailed Injector Data
Dear all,
I'm trying to source a suitable injector for a four valve head engine, the injector used has a twin cone spray pattern. The original injector is more than 20 years old, sufficient time that the injectors used to replace the original choice is no longer available either.
Has anyone come across injector data with more detail than cc/min and impedance. In their motorsport documentation Bosch specify the angle between the two cones, the spray angle of each cone, the angle off axis from a straight shot down the line of the injector body and so on. Has anyone ever seen this level of detail listed off by injector number please?
Many thanks,
Steve
Perhaps someone like Excess Injectors (https://excessinjectors.com/blogs/news/fuel-injector-spray-patterns) that lists data by application, would work for you, as they select injectors with split streams for 2-intake valve engines, etc.
