ECU failure or other wiring issue causing a misfire - Fails to start
I admit I'm lacking a lot of skills to adequately investigate this. I'm still working through all the courses that HPA has to offer.
Short and sweet, I have a MB 2014 W204 C250 sport. The camshaft adjusters were worn, and I was getting a camshaft position sensor DTC fault, P034062. I replaced the camshaft adjusters, position sensors, camshaft solenoids, timing chain, timing chain tensioner, spark plugs, and coils. When I tried to start it, the ECU through a P0301 code and P0342. I sent the ECU out for repair and they told me that they found a leaking capacitor, and that it had a bad drive. These items were repaired and the unit was sent back to me. I installed, and again got the same codes, with one slight difference: P0301 & P0340.
The technician who did the ECU repair stated that it's likely an issue in the car, because of the blown drive to the ECU, there's likely some other cause. But I'm at a loss as to where to look or how to start investigating this issue.
I appreciate any help anyone can offer.
Good morning, I would use an oscilloscope to see the waveform and also do a cam / crank correlation too , as a start , either interference or a actual mechanical issue , but do the basic checks first
Richie, I hooked up my Pico Scope to the terminals on the Cylinder No. 1 coil. The attached images are what the signals look like with just the key on, and when cranking the engine. The BNC inputs have a two-wire connection: black and red. I used the red wire for the input from the coil plug and the black to ground. I have all three channels are sharing the common ground.
Just to see what they look like as ungrounded signals, I included a screenshot of that as well.
In case the file names don't show up when I post this, the pics are:
I have also been digging into the wiring under the driver's footwell, and the truck. So far, I have just exposed the wires. In doing so, I somehow triggered the driver's door chime a couple of times. It's strange because the door was open and never touched while I was lifting the floor cover. I haven't had time to print out the wiring diagram to trace it, but that's probably my next step.
