Ems stinger 4424 v3 help
Hey guys, I have a ems stinger 4424 v3 in my corolla with a 2.6 mazda engine (g6) with a turbo, I have loaded a base map from the v3 software and carried out the ecu setup, I can start the car and have it idle on the base map. Due to it not having ve tables or lambda values (only basic afr readings) what do I do from here. Car will be street tuned as no dyno. Really just chasing values for fuel tables and ignition tables.
Have you looked at some of the webinars covering tuning on the street?
https://www.hpacademy.com/previous-webinars/the-key-to-road-tuning-left-foot-braking/
https://www.hpacademy.com/previous-webinars/268-dyno-tuning-without-a-dyno/
Do you have a wideband lamba sensor connected to the ECU and some way to log data?
Hey David, yes I have a wideband connected to the ecu and the ems stinger v3 software does have a data logger built in
Hey Troy, I'd suggest following our 10 step tuning process that we present in our Practical Standalone Tuning course. This gives you an exact process to follow and there's a bunch of worked examples you can check out to see it being put to the test.
