EMU Black V3 idle ignition angle
Hello all,
For my Gs300 2JZ build, I started with a V2 base map for the EMU black. On the V2 base map, during idle, my ignition angle matched the ignition table values all the time. On V3, it is only matching the target idle ignition angle table values. I’m not seeing this table in the V2 software. I’m not sure how to bypass this or what I’m supposed to do to have it match the ignition table values. Is this due to the ignition PID controller not being set up? All coefficients are 0. Would just need to transfer over these values from my V2 map to the V3 map? I’ll include pictures.
Any help understanding this would be appreciated. Thank you
