Exhaust flap via ECU
I have installed a varex system on my car . I have 2 relays , set up as following :
Relay 1 :
Pin 30 motor +
pin 87a +12V
pin 87 GRN
Pin 85 +12
Pin 86 ADU/ECU
Relay 2 :
Pin 30 motor +
pin 87a GRN
pin 87 +12V
Pin 85 +12V
Pin 86 ADU/ECU
It works for a few times and then it burns the motor due to being constant power fed . even when I remove the +12V for both relays I have power coming to the relays , which I believe is due to reverse polarity from the trigger wire .
Has anyone done something similar ? If not does anyone with more experience with these kinda stuff have any recommendations ?
TIA
From the way you have the relays set up ,it looks like you are using 1 output from the ecu.
This will require 2 outputs.
Switch ON 1 output at a time
Output 1 =open
Output 2 =closed
Set the outputs up on timers in the ecu.
Set the ON time for the amount of time it takes to move the valve into position ,(maybe 1 second more) then switch the output off. (I assume there is no limit switches on the motor)
Output 1 to relay 1 ,pin 85
Output 2 to relay 2 ,pin 85
Relay 1 pin 30 motor+
Relay 2 pin 30, motor -
Wire both relays
Pin 86 = 12v
Pin 87A = gnd
Pin 87 =12v
Thanks for the reply . I am pretty sure I had tried what you suggested but I didn't have a complete circuit with the suggested set up. From what I found it is when I have the car turned off the the relays have constant power and constantly feeds the motor causing it to burn .
But I can give it another try with your recommendations .
No problem.
Also make sure the 12v supply's to the relays are being switched through by the main relay .(the same relay that is supplying power to the ecu , injectors ,coils etc)
This will eliminate any back feeding though the aux output which can in some instances keep the ecu powered up when main relay is off
