So today I was flashing a new file to my truck like I've done a few times before and everything was going well the tune said completed turn ignition off and wait 10 seconds I turned the ignition of and as soon as I did that my dog hit the keyboard on my laptop and hit ok and as soon as she did that I turned ignition back on and the truck now will not start or crank there's a clicking coming from the fuse box and the fuel pump is turning on and off with the clicking. The clicking is coming from one of the relays if i remove the ecm fuse it all stops. Now I've tried to re flash the ecu with different files to see if its file related but it won't connect to the ecu iam using hp tuners mpvi3 and a couple times it said module not licensed i need some help if anybody had run into this. I bought a new ecu but id like to learn how to recover this one if possible thank you in advance
