Histogram set up for MAF
Attempting to calibrate the MAF table on a e92 ecm wit HP tuners, watche the 204 webinar and wa slooking for input on using the factory oxygen sensors.
i cant seem to get the MAF to read on the hystogram when set up for either eq error or afr error, is there something im missing or is that because i need a external input to make that work?
Any input is appreciated
Jeremy
In order to measure EQ or AFR error you will need an external wideband.
thank you, that is what i was assuming
