is Motec M1 just too old? compared to emtron
Hi, the question is focus to compare the flexibility of the different maps that you can use on the motec M1 with the offered package from motec, GPA and GPR for example. Compared to something like emtron, that is very flexible when you want to make your own corrections with your own tables, for example added fuel if EGT get to high, or pull some ignition timing if the fuel pressure drop, or whatever you can think of. I do not see that option with any of the GPA or GPR packages of motec, I know it can be done with the M1 Build software, but for the time that would take, it sounds better just to go with the emtron. I would like to know your experience on this subject. I am big fan of the motec knock control, and the closeloops (fuel and boost) works really well with not much time to be invested from the tuner, so I am just weighing the different options on the market.
