Maxx Race DBW Bosch 0280750009 Setup
Hello People,
iam new here and also to the standalone ecu thing. I want to use a Bosch 0280750009 DBW Throttle for my Volvo B230Ft Turbo engine.
This TB is already listed in the Mtune software as Audi S3 TB with some pre-settings. But iam not shure if they are really correct. I adjusted the motor feed forward spring compensation as maxxecu told me but iam not shure. I also did the calibration, "main throttle closed voltage" is set in the postion, were the spring puts it in "neutral".
But i have some difference between throttle target and position, especially at slightly open throttle. And at the moment the idle is around 1600-1800 rpm with idle control off and 0% throttle position.
So maybe somebody has experience with the TB or DBW in general and could maybe help me out with like a step by step setup to make it run correctly?
Let me know if you need some screenshots, sadly i cant upload logs here.
Best regards and thank you very much!
The "neutral" position is not the "closed" position, you need to recalibrate the throttle body min and max tps voltages.
