My MoTeC lambda sensor is only working about 40% of the time. What could be causing this issue?
Could it be a faulty sensor, wiring, power supply, or ECU configuration?
Has anyone experienced a similar problem or have any suggestions on how to fix it?
Thanks
The value of La1 or La2 (C1-C6) when the sensor is not operational indicates the reason why.
Also, the diagnostics window (press F3) has various diagnostic channels which indicate different fault states relating to the lambda sensor.
