Multilock crimp tool
Hi All,
Could someone recommend a cheap crimper for the multilock 040/070 pins? Doing a one-off harness for an rx7 so don't want to spend a huge amount.
I've currently got the blue pair seen here: https://www.haltech.com/tech-tip-how-to-crimp-like-a-pro/crimp-kit_web/
Unfortunately it doesn't crimp the insulation the correct shape to fit in the connectors
Forgot to add, I'm in the UK so something EU based would be great
Those aren't a terminal that I've had to use too often. I can usually get good results with the generic crimp tools like Haltech sell, however if you want guaranteed results then you're going to be looking at more specialist tools that take interchangeable dies like these - https://au.rs-online.com/web/p/crimping-dies/3715581/
Hey Andre,
Thanks I've managed to source a generic tool like the red haltech now, hoping that will do the trick
@welshkid can you share the link of the tool you bought and how was it?
