NGC4 hem commanded lambda not equal to sum of tables
Checked all the multipliers, am I missing something? gen3 5.7 hemi in a rubicon jeep. If you look at the log at 3:30 you will see a wot pull where commanded lambda is at .853 and at 5200rpm's stars to fall. I cannot figure out why the .853 doesn't match stoich+pe or why it falls off at 5200rpm. Thanks, appreciate any help.
