Plug In ECU for M52?
Hello,
Is there a company currently offering a Plug In ECU for the BMW M52 (currently uses the Siemens MS1 ecu) ?
I contacted LINK about a Plug In and this was their reply :
"Will depend on the stock ECU
If you have the Bosch M3.3.1 then it will.However it is likely you will have a Siemans ECU in which case it will be very different and you would need to look to a wire in unit.RegardsSimon"
Thanks for any assistance,
Scott
Look into VEMS, i know they make them in Europe, but i do however not know whether they fit Siemens or Bosch ECU connectors.
