r33 haltech platinum pro 5.0 trigger kit ross balancer issue.
hi hope alls well!
look ive been having some issues with getting signal, spark, rpm signal on crank etc, then no signal from sensors even passing metal when off the car. the orig cas in n starts fine gets tooth counts etc, the wiring....well tried as per instructions,tried with and without pullups, was a stage where was only getting half the voltage ie 3.5v to one sensor....etc. tried to wire directly to ecu pins etc from haltech site.......either way im suspecting a 12v seperatly to ea sensor is req, earth now this ive heard in discussions that the factory r33 loom your not to use the wire,direct earth is suggested i think...
either way if someones done this can they let me know what they did?
5.0 ignight support was great helped me for days chasing wires with v metre setn up haltech ect but said theresanother issue to sort it first,(had a issue with a blown fuse sorted) haltech checked ecu n was tested ok.
