R35 Coil phasing 4g63 AEM EMS v2
Trying to figure out what the coil phasing should be any help would be great. Running stock crank and cam triggers. 2g eclipse. I’ve verified spark at all coils. Just need help with the phasing. Thank you
I'm sorry, but what exactly do you call phasing? Can you please elaborate it?
I figured it out, instead of using zero I started with 1.000 for coil 1, 4.000 for coil 2, 2.000 for coil 3 and 3.000 for coil 4. Car started right up.
It's just cylinder firing order...
Correct.
