Hello all,
I have a 91 Nissan Skyline GTR with AEM V2 and it has the AEM 24 tooth CAS. Car has 750CC high impedance injectors. Resistor has been removed and harness modified. All the deadtimes set to injector manufacture spec. MAF is deleted, running speed density and tps based fuel. Ignition Timing verified with timing light during cranking. It currently will not start. AEM does not have any real support or a usable base file(AEM V2 supplied RB26 base files are brutal). Car was running before with previous stock injectors that were bad although it did run rich (10:1 AFR) and had hard time starting with those as well.
I am hoping that someone on here is familiar with the AEM V2 and RB26 to help me sort this issue out or point me in a direction to tell me what is going wrong or even has a good base file that I can work with?
I can attach some maps here if someone can help. Here is the map with only injector wizard used to change injector size from stock 440 to 750 and deadtimes set, nothing else I believe.
Thanks,
Dave
