Tailpipe sniffer question
Hi everyone,
I got a homemade dyno for bikes and the tailpipe sniffer that Im using is basically a tube with a lambda probe. Someone knows where to buy or how to get an sniffer with air pump like the one that comes with the dynojet dynos? I guess is more accurate than what Im using right now but I cant find anything anywhere.
Thanks in advance
I have considered making something like that. You just need a small fan to draw air from the tube and past the sensor.
Ok, im thinking that I could use a vacuum pump for the extraction. Most of the sniffers I saw are using sort of a vacuum pump or compressed air. I also saw this one that uses compressed air but is out of stock: https://sportdevices.com/product/lambda-pump-block/
