AEM UEGO wideband sensors with MoTec M130 ECU?
How to Degree a Cam
Working on an SRT10 Truck and I want to use dual AEM UEGO wideband sensors with a MoTec M130 computer. There is an MoTec LTC lead (4 pin) on the JRR harness I got, but how would I wire both UEGO sensors to this since the UEGO sensors are analog and not CAN? Any help would be appreciated!
I'm pretty sure the JRR packages on the M1 support analog Lambda inputs. You would need to wire them to an available Analog Voltage input -- you can find available inputs in M1 Tune when you select the resource for the AEM Wideband. Your best support would come from John Reed Racing.
The LTC connector would only have 12V Power and the CAN Hi/Lo signals. Easy button would be to use the MoTeC Dual LTC connected to that connector.
